Thread: Greetings from Boston, MA
    dannysal's Avatar
    May 2013
    Boston, MA
    2
    Hello everyone and happy Friday.
    Of course, I have some pool problems and that is why I am here. It seems like the first thing I need to do is get a good test kit. So, I will do that, test the water, do some research on this forum, and post again if I still need help (I'm sure I will).
    Danny
    In-ground Pool
    16X32
    24,000 gallons (I think)
    vinyl
    cartridge filter
    3/4 HP pump
    Raypak gas heater
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Greetings from Boston, MA
    Welcome to the forum
    You're done SLAMing when:
    dannysal's Avatar
    May 2013
    Boston, MA
    2
    Hello again,
    My test kit arrived in the mail today so I will be testing when I get home tonight. The pool water is clear but I have some stuff on the bottom of the pool. I vacuum and it comes back.
    Here is a video:
    http://youtu.be/hjzJmqaLnJ4
    I realize the readings from the test kit is critical before anyone can offer guidance so I will get those posted asap.
    In-ground Pool
    16X32
    vinyl
    cartridge filter
    3/4 HP pump
    Raypak gas heater
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP
    Watched your video. What type of vacuum are you using? Does the debris completely clear after vacuuming and then come back after several hours or the next day? I once had a small tear in the vacuum bag, but the symptom of that was that not all of the debris seemed to get picked up by the vac. In actuality, it was getting picked up but was redeposited due to the small tear.
    Look forward to your test results.
