Results 1 to 12 of 12
Thread: Purchased a SQL1072 3/4 HP 2 Speed 115V
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello All,
    Purchased a 3/4 HP 2 speed motor today for my pump. It's re-manufactured so the price was right. Looking forward to getting it installed. I'll replace the seal and add a hi/low switch to the cover when it comes in and use my same timer. I'm planning on running it on low. I'll update and let you know how it works out. I'll keep my old motor as a backup. The pay back should be about 2 years (20 months).
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Purchased a SQL1072 3/4 HP 2 Speed 115V
    Looking forward to seeing how it works for you.
    Apr 2011
    Murrieta, CA
    2,360
    Ordered from Digikey a toggle switch SPDT (PN EG4816-ND) for $4.28 (rated for 2 hp) and rubber boot (PN335-1125-ND) for the switch $3.20 with shipping came to $10.28 for a high/low switch for the motor. I'll drill the cover and mount the switch.
    Apr 2011
    Murrieta, CA
    2,360
    Got it installed today.
    High 6 psi/52 GPM
    Low .5 psi/23 GPM
    Increased my pump run time to about 20 hours.
    Adjusted the pressure switch on the pool heater. It works on low. SWCG is working no issue.
    I'll update tomorrow.
    38,284
    Do you have a flow meter that is provided that data?
    Apr 2011
    Murrieta, CA
    2,360
    Yeap sure do. Its a Blue White Flowmeter Model No. F-30150P
    Apr 2011
    Murrieta, CA
    2,360
    Turned down the pump run time 12 hours on low. SWCG 80%. Pool is in Full Sun. Also adjusted the main drain and the skimmer to fully open. Skimmer action was slow anyways. Figured since heat rises, take from the bottom of the pool.
    Only time will tell.
    We had a big pool party. About 20 people in the pool, the bottom is cloudy, FC is at 6 and CC is .5. Just waiting for the filter to do it's job.
    Apr 2011
    Murrieta, CA
    2,360
    Here's a picuture of the motor with the switch:
    Apr 2011
    Murrieta, CA
    2,360
    Just an update. Happy with the setup. Pump runs 10 hours during the summer on low, about 5 hours during the winter.
    Orlando, FL
    690
    I know this is old but I am always amazed at the wealth of information on this site. I should stop reading because I am creating new projects for myself.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Apr 2011
    Murrieta, CA
    2,360
    LOL. I has a single speed 3/4 hp, very happy with the "upgrade". My SWCG needs to run for 10-12 hours in the summer. 95% of the time the motor runs on low. Saves me money.
    Orlando, FL
    690
    I am walking away. The next project on my list is a heater and that is ALL for 2015. Sigh.
