Results 1 to 12 of 12
Thread: 1 Hp Jandy pump
    May 2013
    Ocean County NJ
    183
    1 Hp Jandy pump
    Based on my pool size @13,000 gallons I was recommended a 1 hp jandy stealth pump.. My question is.. I heard that a variable or a 2 speed pump is recommended for cost savings. Is it necessary on such a small pump?
    Thanks
    Freeform gunite, 14,000 gallon saltwater sport pool.
    10 ton moss rock w/ waterfall, 50 sq ft raised spa.
    Bluestone coping, pebblesheen. Jandy pro flo 1 hp pump, legacy 325k heater.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: 1 Hp Jandy pump
    It will save you money in electricity to go with a 2 speed, even a 1 HP pump can cost hundreds of dollars per year to operate depending you electricity cost, length of swim season, etc.
    38,548
    Re: 1 Hp Jandy pump
    On low speed it uses 1/4 the power to move 1/2 the amount of water as on high speed. So even doubling the runtime on low to move the same water would be a 50% power savings.
    Do you already have a pump you are replacing? Most 2-speeds are 230V, so it is a little more difficult to find the 2-speed pumps if you are only wired for a 115V motor.
    May 2013
    Ocean County NJ
    183
    Re: 1 Hp Jandy pump
    No not replacing, going to be building and want to make sure I have proper equipment in place. I guess even at the small hp still makes sense for a 2 speed for savings.
    Thank you!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: 1 Hp Jandy pump
    Even the jandy stealth 1hp 2-speed is pretty big for your pool unless you will have high volume water features. If you want to stick with jandy, the flopro 1 hp 2-speed may be a better fit.
    Post the list of your equipment and details and we can comment.
    May 2013
    Ocean County NJ
    183
    Re: 1 Hp Jandy pump
    Will be using 325 btu nat gas jandy legacy heater. Cartridge filter.,I dont like the de filter due to backwashing will have waterfall feature over rock. Going with pebble sheen finish.
    G
    38,548
    Re: 1 Hp Jandy pump
    What will the volume of the pool be? Make sure they do not undersize your cartridge filter as that too can be a pain.
    May 2013
    Ocean County NJ
    183
    Re: 1 Hp Jandy pump
    Approx 13 k gallons, what color is your pebblesheen?
    38,548
    Re: 1 Hp Jandy pump
    Blue Granite
    Make sure your Cartridge is at least 190 sqft for a 13k pool.
    May 2013
    Ocean County NJ
    183
    Re: 1 Hp Jandy pump
    K thanks, we are thinking blue granite also. Are you happy with color? Do you have a picture?
    38,548
    Re: 1 Hp Jandy pump
    It is a nice blue. We were looking to avoid any aqua/green.
    This is all I currently have available:
    your-pool-from-space-t27529-40.html#p256886
    May 2013
    Ocean County NJ
    183
    Re: 1 Hp Jandy pump
    Looks great from above! Ours is only going to be 5 ft deep. So i am hoping not going to look too grey.
