Thread: Coverstar pool cover switch replacement
    I have a Coverstar pool cover and the "cover/uncover" switch went out. (It works one direction to uncover the pool, but not to cover). We confirmed that the motor is fine by hardwiring - it works both ways. The pool technician can get a replacement switch but it will cost $140!!! I can't find a source for this on the internet.
    Can a switch like this be repaired?
    Any sources you can suggest who might have this switch or a compatible switch that's cheaper?
    #'s on the switch:
    OE 3751
    20A-120/277u AC/CA
    27' Round, 17,000 gal, AG, installed July 12, 2013.
    Splapool 1HP pump, Distinction 20" sand filter 200 lbs, Feherguard solar cover & reel.
    22,553
    Re: Coverstar pool cover switch replacement
    Is that the key switch?
    There was a discussion last year about the coverstar switch and I don't remember there being a generic replacement.
    I remember looking at the wiring but don't remember how it's wired now.
    You can get an industrial switch that should do the same thing but it's probably as much money.
