Results 1 to 11 of 11
Thread: BBB readings
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    BBB readings
    Hey all, I checked my cya yesterday with the tf100 and it read about 25. I checked again today and it read the same. Last night I checked the chlorine andit was at 1ppm. I then added 3 cups of 6% bleach last night to see if it would raise when I checked it this morning.
    I checked it and I'm currently reading .5 on FC. Any suggestions?
    30' by 54 Above Ground Pool 22000 Gallons
    1.5HP 2-Speed Hayward Powerflo Matrix Pump
    24' 300lb Hayward Sand Filter
    TF100 Test Kit
    Youngest Pool Enthusiast(Hopefully)
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: BBB readings
    We'd love to help, but we need more information...
    What's the problem?
    How does the water look?
    How big is the pool? (Please put all your info in your signature: User Control Panel -> Profile -> Edit Signature)
    How are you chlorinating?
    Can you post a full set of test results?
    CYA shouldn't change unless you dump water or add more.
    FC goes down quickly because it breaks down in the sun (normal) or because something is living in your pool and the FC is trying to kill it (not normal).
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Re: BBB readings
    Oh okay sorry man. I only use bleach as chlorine. I have 24 by 52 above ground. I run the pump all of the time. The water looks really clear with a very slight cloudiness to it as in barely noticeable.
    TF100 Test Kit
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: BBB readings
    Ok, need a little more info....
    Recently opened? Or opened for awhile?
    38,463
    Re: BBB readings
    Sounds like you have not been staying on top of maintaining the FC and now need to go through the Shocking Your Pool PROCESS if the water is cloudy ... likely pointing to algae.
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Re: BBB readings
    It's not really cloudy it just has a minor not clarity to it. It has been opened for about a month or so now. Ill post pictures to show you guys, I've been adding bleach everyday, even before I got the tf100. Always adding extra just incase I was off.
    Thank you guys, keep the suggestions coming. I'm in the process of trying to calculate how much to add in nightly.
    TF100 Test Kit
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Re: BBB readings
    TF100 Test Kit
    38,463
    Re: BBB readings
    Not to be snarky (a word?), but if you were staying on top of the FC ... it would never have dropped to 1ppm or 0.5ppm like you reported in your first post.
    It should never have been allowed to get below 2ppm (based on your CYA level) ... once it did, stuff can start to grow and cause the clarity issues ... especially since you are running the pump 24/7 and thus not likely due to dirt.
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Re: BBB readings
    Thanks man I'm just really inexperienced in this category but am willing to learn. What would you recommend I do first?
    TF100 Test Kit
    38,463
    Re: BBB readings
    Given you CYA of 25ppm, your shock FC level is 12ppm ... check that the pH is in the lower 7s and then go through the Shocking Your Pool PROCESS until you pass the 3 criteria ... this may be very quickly if there is not much in the water.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: BBB readings
    I'd guess that you will be done with the process in a day. Just hold it at shock level and I bet it'll get in order fast.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
