Results 1 to 11 of 11
Thread: What test do you use the speedy stir on? Updated w/ pics
    May 2013
    Long Island NY
    419
    I think I need this. What test will I be able to use it on? I want to get my test as accurate as I can and I think this is the ticket.
    Thanks
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    38,295
    Re: What test do you use the speedy stir on?
    Everything except the CYA and pH tests ... although some even use it for mixing the CYA test.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,008
    Quote Originally Posted by samt
    Thanks
    Everything but the pH. I have extra vials and stirbars so I can run everything before I have to stop and wash the dishes.
    22,550
    Same as Richard, everything except the pH test, and I'd probably use it on that one if I could find a stir bar small enough to fit in the test block and spin!
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    dittos to Jblizzle.....would that be the same as dizzle to blizzle??
    Makes the tests go alot faster.
    May 2013
    Long Island NY
    419
    Thanks everyone. I'm sold. O'boy a new toy.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Sam,
    Get it, you won't regret it. It makes testing a LOT easier!
    Dave
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    May 2013
    Long Island NY
    419
    Well, I hope you guys don't laugh, but I made one. And it works like a champ. I also ordered a stir bar on eBay for 5 bucks. My homemade stir bar was the weak link. I didn't get a good vortex.
    My total investment is 8 smackaroos.
    I made it out of a computer fan motor and used a 9 volt battery for power and stuck a radio shack toggle switch on it and stole a tuppware container from the lady that runs the house to mount it in.
    There's a ton of videos on utube on how to do this.( magnetic stirrer)
    Usually things I try to make it always seems it just better buying the real thing, but this came out great and works really good.
    Sam
    38,295
    I would like to see what you came up with
    May 2013
    Long Island NY
    419
    I will post some pics, it may be a day or two. But there comming.
    Sam
    May 2013
    Long Island NY
    419
    Well here she is, homemade magnetic stirrer.
    Once I get the real stir bar I think the vortex will go to the bottom.
    It has just a 1/4 round magnet in there now and it actually does real good with just that.
