Adjust PH first or TA?
pH is fine, but that TA is a little low.
Since you are apparently partially using pucks (how high is your CYA?), I would raise the TA up to 100ppm or so with baking soda. Then recheck the TA and pH.
Thanks for the quick replies!!!
My CYA is 32, I don't use the pucks much. I'll adjust the TA to 100 with baking soda then recheck both TA and PH..
Thank you again for always being so quick on the responses!! Love TFP!!
