Results 1 to 8 of 8
Thread: Adjust PH first or TA?
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    Hello,
    I use BBB with the additon of pucks. Currently my PH and TA are a little low. Which should I adjust first? Or does it matter?
    Thanks!!
    30' Above Ground 18,000 gallons, Sand Filter, 1.5 hp Jacuzzi Pump
    38,452
    Re: Adjust PH first or TA?
    What are the actual numbers? You "little low" might in fact be "just right"
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    PH is 7.2 and the TA is 40
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by bbecky75
    TA first.
    You're done SLAMing when:
    38,452
    pH is fine, but that TA is a little low.
    Since you are apparently partially using pucks (how high is your CYA?), I would raise the TA up to 100ppm or so with baking soda. Then recheck the TA and pH.
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    Thanks for the quick replies!!!
    My CYA is 32, I don't use the pucks much. I'll adjust the TA to 100 with baking soda then recheck both TA and PH..
    Thank you again for always being so quick on the responses!! Love TFP!!
    38,452
    Oh, well if you do not constantly use pucks, you may not want the TA quite that high then ... maybe 80-90ppm
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    Ok, thank you!!!
