Thread: Total alkalinity and muriatic acid
    May 2013
    Hartsville South Carolina
    46
    Hey all,
    As of this morning.
    FC 4.4
    PH 7.8
    TA 150
    CH 150
    CYA 60
    I am in the process of lowering my TA although it hasn't moved much over the last week. I have been following the directions of the Taylor acid demand test. Today I plugged in all my numbers into the pool calculator and it gave me different results than Taylor. Taylor says add 1.72 qts. Of acid and pool calc. Says add 2.6 qts. Is that because of the high TA that is present and Taylor's doesn't factor that or am I doing something wrong. I want to drop from 7.8 to 7.2 then raise PH back up by aerating the water. What do you all think? Thanks. Oh yeah I'm also gonna add more cya to bring it up to 80.
    Ryan
    23k gal, IG, vinyl, Pentair sand filter, 1 hp single speed pump, pool pilot digital swg, Hayward sharkvac. Built May 2013
    38,394
    Re: Total alkalinity and muriatic acid
    Likely your assumption is correct that the Taylor does not fully account for the TA.
    I trust the poolcalculator.
