Thread: Low Chlorine Read
    Low Chlorine Read
    We can't get our chlorine readings to come up after shocking pool two nights in a row. Have 4 pucks in skimmer and readings haven't gone up or down.
    FC-very low
    CC-very low
    PH-OK
    TA-OK
    CH-Ok but a little high
    CYA-low
    Water is clear but not the glassy clear
    Thanks!
    22000 gallons/AG/DE/hayward powerflo matrix/hp 1.0/rpm 3450/amps 13.8
    38,275
    Re: Low Chlorine Read
    Welcome to TFP!!!
    Those are not NEARLY specific enough for us to provide any useful help. Let me guess, test strips? They are worthless.
    Order one of the recommended test kits and read Pool School (button at upper right of the page) so you get an understanding of the chemistry.
    Likely you need to go through the Shocking Your Pool PROCESS to clear the water, but that is not possible using test strips.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    What he said ^
    Bite the bullet and spend the $$ on a proper test kit. Or you will be repeating this: http://www.troublefreepool.com/post501948.html
