Thread: Need advice on gas service for gas pool heater and NG grill
    Exton, PA
    249
    Ok, my wife is thinking that a heat pump might not generate the heat required for her to be cozy. Not sure I disagree with that. In addition, we currently have natural gas service and I would love to have a gas grill, instead of propane. Add to that the lower cost of NG in our area and gas heat is worth exploring.
    I, or should I say, my wife realizes the expense of installation, having a pro install the lines, etc. but she's hot dammit and wants to swim every night. It is her hotness that's driving this project...so to speak
    1 - The gas company sent me an upgrade service form, for an estimate. A new meter is free, but upgraded service will cost. Looking at the specs in my signature, would you suggest 400,000 BTUs? I realize that bigger heats faster, etc. I thought there might be a chart that shows the break even point, where larger actually shows a diminishing return.
    2 - What PSIG (pressure) am I looking for? 2 PSIG, 5 PSIG, 10 PSIG, Low 5" (.18 PSIG), 12.2" (.44 PSIG), or line.
    3 - Any insight on the outdoor NG grill, as far as location, running the lines, etc.
    4 - any other pitfalls I can avoid?
    Thanks
    18' AG pool, 7,646 gallons, Sun from 11:30AM-2PM.
    Pentair Dynamo 1hp pump, Intermatic Timer (6/17)
    Pentair Sand dollar filter - 100lbs, 35gpm
    Pentair Lil' Shark cleaner, TF-100 Kit
    Raypak 206A 200K, BTU gas (6/17)
    Jun 2012
    western NY
    1,560
    Re: Need advice on gas service for gas pool heater and NG gr
    Not sure you need the 400,000 heater. I have an 18' with a 100,000 Hayward that will give me almost 2 deg/hour on an 70-75 deg day. I feed mine with a 1/2" line and have no problems with it. I never clocked my meter with the heater running to see what my actual input/output is but based on the weight and Delta T I get it has to come in right around the 100,000 BTU mark. I also run a 17 year old Ducane gas grill on the same line.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Exton, PA
    249
    Thanks. I put 200,000 down on the power company's request form. I have a high pressure service now, with a regulator, so I shouldn't need added service for this:
    Current:
    Furnace - 100,000
    Water Heater - 40,000
    Range/Oven - 40,000
    Gas Dryer - 20,000
    New
    Pool Heater - 200,000
    Gas Grill - 35,000
    Worst case, the only simultaneous running would be the gas grill, with the pool heater, and maybe the hot water heater. I'm not cooking on the grill AND the oven. Maybe boil water on the stove, but I'm guessing a NG grill will cover most all cooking at once. Nor am I running the furnace while the pool is being heated.
