- May 30, 2013
- 1
I split your topic off to begin your own instead of hijacking the original thread - Moderator
I have owned my 35,000 gallon inground vinyl liner pool for 7 years. I have never had one single problem. I replaced the liner two years ago and put all new water in (obviously) WELL THIS SUMMER OUT OF NO WHERE IT LOOKS LIKE ANTIFREEZE and nothing will kill it. The guys at LESLIE's who have always been so great to me cannot help any longer. Here is what has taken place over the last 2.5 weeks. 100 pounds of CHLOR BRITE 20 pounds of fressh and clear. YELLOW OUT, GREEN OUT ... 20 pounds of CAL HYPO. algaecide when he opened it... etc etc. Cannot get it to turn the slightest blue no matter what I do... 5 days ago I decided to change the sand out and get all new insides of the 300 pound sand filter. There is not one spec of leaves dirt algae (i cannot get anything in my pool cleaner) I don't know what else to do. So i took the chance and drained it to the top of my bottom step. My guess.. Is atleast 10,000 gallons of fresh water. Not to mention the fact that I have vaccummed on waste several times and changed my light... So my water is pretty darn new... Anyways, now I have tablets in the cholorinater 15 pounds more of shock with all this new water and filter sand etc etc. you would think atleast something would resemble blue... but it seems to get worse and worse and worse... guys won't help me at the store because PH is perfect CYA is high but not to high for chlorine to not work. Alkalinity is perfect chlorine is showing its there but I cannot see but more then 2-3 feet down... AND IM TELLING YOU ITS GREEN!!!!
I will take any advice even if I have done it already... Normally it costs 750 tops for the whole year.. Great investment as much as we usually use it. but now I'm approaching $1500 already and I cannot get any results... Jet pressure it perfect... plumbing has even been redone on the inside where my filter is... NO EXCUSE THAT ITS STILL EITHER AN ELECTRIC GREEN LIKE ANTIFREEZE OR A SWAMP... whatever it is I NEED HELP...GREEN GREEN GREEN PLEASE GO AWAY!!!
Im new to this site so I don't know how to get responses... SO if you have time or If I can trouble you... My email is [email protected]
THANK YOU!!!!
THANK YOU!!!!
