Thread: Dirt Devil ROGUE
    dahncke's Avatar
    May 2012
    Indianapolis metro area
    32
    Dirt Devil ROGUE
    Picked up one of the Dirt Devil ROGUE In-Ground Suction-Side Automatic Swimming Pool Vacuum Cleaner.
    This is the first auto pool vacuum we've owned. We picked it up because the price was right. They are on ebay for about 175. If figured at that price, it was worth a try. Here is my review for anyone considering one.
    First, it works. When I opened it the thing looked so simple, I couldn't imagine that this thing was going to work. It isn't fast, and it isn't especially efficient... but, it works.
    Below is a photo of it in action. It climbs walls well and generally gets about 95 to 98% of the pool. I have found that there are places where the pool floor elevation changes that seem to get missed. It appears that if you pull the vacuum out and start it again from a new starting point, that new pattern will most likely hit those spots. So, for those reasons, if you are a perfectionist, you will find fault with it.
    Set up is not hard, but cumbersome. The hose has to be pulled apart into 2 ft sections and reassembled each time you use it. However, the fact that it disassembles means it is easy to store.
    The thing runs off the pool pump's suction without anything else.
    Hope this helps. If anyone has specific questions, let me know!
    Kayak Pool - 12 ft. x 24 ft. rectangular, 5˝ ft. deep end
    Frog System, Sta-Rite-Modular Media Cartridge Filter, Pentair 1 H.P. pump
    AquaPRO Pro500 heat pump & Automatic AutoGuard™ Pool safety cover
    Re: Dirt Devil ROGUE
    Thanks for the review!
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
