Thread: Rust spot on vinyl liner
    May 2008
    Newburgh, IN
    I have an IG vinyl pool with a Watermaid salt system. It is around 33,500 gal. I opened up this season to find that I missed a hair bobby pin that was sitting on the bottom when I closed last year. It has left a rust spot on the liner. What can I do to get this off? I have tried to brush it off with no luck . It is time to move to the next step. Any ideas??
    38,000 gal IG Vinyl
    Hayward Northstar SP4015X20 2hp uprated pump
    Pentair TRITON II TR100 Sand filter
    Mar 2007
    Morris, IL
    I believe that vitamin c tablets will work.
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Yes, vitamin C should take care of it. Crush several vitamin C tablets and put the powder in a sock. Place the sock on the stain for a couple of minutes and the stain should be gone. If it is only partially removed wait 30 minutes and then repeat the process with more vitamin C.
