Results 1 to 9 of 9
Thread: Backwash Valve Problems
    Split by moderator from HERE. Please start your own thread with your own questions. Thanks, jblizzle
    This just indexed when I googled the term "hayward spider valve stuck open".
    Here is my problem. I had a leaky spider valve so I bought another one. The handle/valve assembly is exactly the same as my old one. With all equipment turned off, I removed old one and try to install new one. I got the tab matched up so it should drop right in however unless I turn the handle and open the valve a bit, the thing won't push all the way in (even using nut). I put the old one in and have the same problem however the old one wasn't making my pool look milky.
    Help
    11.5k gal, IG Plaster (2001), 1.5 HP AO Smith Centurion Pump, Purex Triton FNS Plus 60 sqft DE filter
    38,246
    Re: Constant grief with spider gasket for Hayward filter
    I do not understand. So you can not put the top back on? But it is making the water look milky?
    Re: Multivalve Problems
    It is almost like the whole valve is too long which it isn't. If I open the valve just a bit before installing, it fits all the way down flush with the piping and seals nice. It won't push all the way down to close though (doesn't ride groove down to where it makes a turn to lock) so it's open and I think the D.E is what is making the water cloudy. The thing won't even come close to fitting if it is in the closed position so the nut just spins on top of the threads.
    38,246
    Can you post a picture of the valve because I think we are taking about different types of valves.
    I guess we were, it's a backwash valve not spider.
    38,246
    Yup. I am not familiar with how those are put together. So hopefully someone else will have an idea.
    Re: Backwash Valve Problems
    okay. I don't know if it is just me, but i need to see pictures of your actual slide valve on the filter. I am not really understanding what is going on. Are you saying that the handle doesn't go all the way down? Are you seeing water come out the waste port when it is on filter mode?
    I'll pop off a pic tomorrow when its light out. No water is coming out of it though. The way the handle on the valve works is when you pull it up in the "open" position you can see a groove in the shaft where it slides down and then the handle turns at the bottom to actually lock it. When I install it, when you push the handle down, it doesn't go all the way down so it is slightly open and wont lock.
