Thread: Broken Bottom Drains - Temp Fix Ideas
    SO we are having a party on Saturday, and the screws off both of the bottom drains are broken, so they need to be repaired - 10ft deep, and to deep for my belly to hold down and repair.
    SO... I was thinking..... Let me know if okay to do for temporary.
    Was thinking about putting weights on the bottom of the covers to hold them in place for the day. Do Small enough Fishing Weights, so worst case if the weights broke off, it would be small enough to make it into the basket.
    Do you think it might work? Or if I put the suction only to the bottom drains during the party that the suction would hold them in place?
    Give me a YEA OR NA
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Broken Bottom Drains - Temp Fix Ideas
    Why not just shut off the bottom drains? Then there's no worry about entrapment, and if someone drops a toy, it won't get drawn up the pipe to clog it. You could also cover it with a suction cup antislip bathtub shower mat.
    It would be dangerous for anyone to use the pool while the bottom drain covers are loose or broken. They should be properly replaced with up-to-code covers before anyone swims. Putting all of the suction on the bottom drains, with insecure covers, would make a dangerous situation even more dangerous.
    Support the site
