Thread: Molars to PPM Salt (NaCl) Calculation
    Aug 2008
    Honolulu
    429
    This question is I think something chem geek will be able to answer, or others among you who are chemistry geeks.
    The reason for this question is that it relates to another question regarding saltwater pools that I want to ask, but I want to make sure I am calculating correctly.
    So here are two question:
    If NaCl (Salt) has a molar mass of 58.44276 would 1.7 M of NaCl, in a 10,000 gallon pool, equate to 2624 ppm, and would 2 M of NaCl, in a 10,000 gallon pool, equate to 3088 ppm?
    Thank you to those that can answer.
    10,000 gal plaster pool,3/4 hp WhisperFlo pump, Sta-Rite Great White GW9500 pool cleaner, Hayward 300 lb Sand Filter
    Use Magenta Stuff for Iron and Silica control.
    Balance: pH 7.7 Cl 7 -8 Alk 70-80 CH 325 CyA 30 in winter - 50 in summer NaCl 1010 TDS 1200
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Molars to PPM Salt (NaCl) Calculation
    If you mean Molarity (which equals moles/L) then:
    (1.7mol/L)*(63.55g/mol)*(1000mg/g)= 108305 mg/L= 108305 ppm or 10.83%
    (2.0mol/L)*(63.55g/mol)*(1000mg/g)= 127100 mg/L= 127100 ppm or 12.71%
    If instead of the above, you mean moles (not Molarity) then:
    (1.7 mol)/(10000g)*(10000g/37854.1L)*(63.55g/mol)*(1000mg/g)= 285.3 mg/L = 285.3 ppm
    (2.0 mol)/(10000g)*(10000g/37854.1L)*(63.55g/mol)*(1000mg/g)= 335.7 mg/L = 335.7 ppm
    Mar 2007
    San Rafael, CA USA
    12,082
    Why are you dealing with moles or molarity (moles per liter)? Don't you just want to know the concentration of salt in the pool when you add a certain amount to it? Or you want to know how much to add to get to a certain salt level? For either of those questions, you can use The Pool Calculator.
    Aug 2008
    Honolulu
    429
    linen,
    Than you for your reply.
    I meant Molarity (which equals moles/L), and as the numbers are different from what I thought they might be I have no question to ask.
    chem geek,
    No, the question was for another reason, but as the numbers are different there is no question to ask. To check my salinity I use strips which were always close to the Taylor's salt test kit. Taylors salt test can no longer be legally shipped to Hawaii due, according to Taylor, new Federal regulations, nor can the iron test for the same reason.
    Thank you both for your reply.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I'm guessing it's the Chromate in the salt test, but what is in Taylor's Iron kit?
    Essential Links:
