Thread: High PSI - Help
    High PSI - Help
    I just opened my pool for the season and did my normal routine to open. I ran the pump as well as backwashing and noticed that my PSI is around 34. However, when the pump is off, the PSI is at 22. Does this mean my PSI is actually 12 and that the guage needs to be replace or re-inserted?
    Thanks!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: High PSI - Help
    Replace the gauge...I would not trust just using the delta.
    Re: High PSI - Help
    Quote Originally Posted by linen
    Will do. However, the pool appears to be operating normally. What are some symptoms of such a high PSI? Just want to make sure I can sleep tonight.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: High PSI - Help
    Low flow rate at the return.
