Thread: Need new DE Filter Casing
    Is it possible just to get a new de filter casing?....I have an old metal PacFab that is rusted and is starting to have pinhole size leaks on sides. I just put in new filters...only thing I'm seeing online is the whole system with multi-port and sometimes pumps. My filters are 24sq ft...I was told by my pool store that my filter area might be too small for my 12K gallon pool but I inherited this pool, so why would they put a smaller filter in to begin with?
    I would like to get a Hayward filter casing that would work with the 24 sq ft filters. Is it possible just to get the casing?
    12K IG Gunite, DE, 1HP, SWG
    38,284
    Re: Need new DE Filter Casing
    Usually the filter parts would end up costing almost as much as a new filter.
    You are right though that your current filter is a bit too small. We would recommend as minimums:
    178 sqft cartridge
    20" sand
    33 sqft DE
    I am going to look into a Hayward de3620. I assume that might work better than the one I have now. I found one for just under $500 free shipping.
    I do have some brownish-black staining where algae growth was bad. Other than draining and acid-washing, does the black algae solutions work? I saw some videos of algi ban and lo chlor. What is recommended?
    38,284
    Just use chlorine in the shock process and the stains should lighten over time.
