Thread: Is this an acceptable way to maintain PH?
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    I have a fairly new pool with a SWCG and two waterfalls. This contributes to a PH rise of .2 daily. I have been adding acid to down it to 7.2 and bump it down when it reaches 7.8. Is this an acceptable way to manage the PH? In other words, should I be adding acid daily to keep it at a specific point or is it ok to keep it within this range by adding it every four days?
    Thanks everyone!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,658
    Re: Is this an acceptable way to maintain PH?
    Keeping it in the range is good enough even that they say that your FC is most effective when PH is at the lower end of the scale.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    You're doing fine. Just pay attention if the kids complain of sore eyes, some people are more sensitive to that. Tears are about 7.4.
    Oct 2012
    605
    Thank you Richard and Woody. I appreciate the information.
