Thread: I NEED HELP!!!!
    I NEED HELP!!!!
    I have a sta-rite heater and im starting it up for the first time this season, when i turned it on it started heating but the service heater light turned on right away. I did a reset, water is flowing through it too. What could be the problem?
    [center:w4qsfy87]Intex 4600gal vinyl, above ground. Sand Filter with 1/2 HP pump. TF-100 Test Kit & XL Option
    Pool isn't set up yet.[/center:w4qsfy87]
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: I NEED HELP!!!!
    Welcome to tfp, faisalkhalili
    I am not familiar with your heater buy hopefully someone who is will reply soon
    I am assuming when you reset it, it still did not light?
    What is the model?
