We usually ignore 0.5 ppm, at least when one is using a 10 ml sample size. It just means <= 0.5 ppm. You can always rerun the test using a 25 ml sample size which would then have 0.2 ppm resolution per drop. I suspect you've got <= 0.4 ppm and possibly <= 0.2 ppm CC. Just note that CC tends to build up in indoor pools because their is no UV in sunlight to break them down or to produce hydroxyl radicals from the UV breakdown of chlorine which tends to reduce precursor organics. So indoor pools often use supplemental oxidation such as non-chlorine shock (MPS), UV (technically not oxidation, but breaks down chemicals anyway), and sometimes ozone if special degassing is done.
