Thread: Rustoleum: Deck and Concrete restore
    dremin2flyhi's Avatar
    Jun 2010
    Darlington, SC
    121
    Anyone been brave enough to give the Deck and Concrete restore a go yet ? I am tired of the constant sealing and staining ...
    24' x52" Sharkline Venture (May 2016) ABG (13,500)
    Hayward S180T15932S --Sand filter/ Flo-Matrix pump pack
    Aquatrol-RJ SWG-- Nitelighter NLMC
    Dolphin E10
    Duraspa G2- Premium hot tub --Rotomold style
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Re: Rustoleum: Deck and Concrete restore
    I have done two for clients. It does get mixed reviews. It will peel after a while but it should last longer than stain. Did one about 4 years ago. It was not Rustoleum brand but it was manufactured by the same company. It just started to peel. The second was done last summer. Several things to keep in mind. I don't know how they came up with the coverage figure but they were WRONG. I think I got a little more than half of what was printed on the pail. Also the darker it is the hotter it gets in the sun. Almost burn the feet hot so I would go light. It does not cover 1/4" gaps. If the board is split then it will need to be nailed back down. Finish nails works good along with construction adhesive to prep for restore.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
