Thread: Broken skimmer support ring - how replace??
    I had problems getting good suction on my vacuum. Feeling around the skimmer led me to find that the support ring that holds the skimmer basket up is broken. I pulled it out, put the skimmer vacuum plate on and--voila--good suction. I want to replace the support ring but it seems like it is larger than the hole at the top of the skimmer into which I'd have to insert it...the only reason I could get the broken one out was because it was broken and I could bend it quite a bit. I have no idea how to get a new one in. It's a Hayward skimmer BTW, no idea of model number.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Broken skimmer support ring - how replace??
    Welcome to tfp, bugsy905
    I am not sure what ring you are talking about. Maybe you could post a picture?
