Newbie here...
I am replacing a Pentair Whisperflo with an Intelliflo VS. Should I buy and use the quick disconnect fittings or stick with the basic CPVC adapter type fitting? I know that the quick disconnect will make removing the pump easier if that becomes necessary, but I have never removed the original pump since it was installed. Plus, the few pool plumbing leaking issues I have had so far have always involved quick disconnect unions. However, if the collective wisdom here is to go with the quick disconnects, I'll spend the bucks for those. Thoughts?
Thank you!
Keith
Thank you!
Keith
