Thread: need some help with a pump
    May 2013
    long island, ny
    2
    so we bought the intex 18' round pool last year and the pump that came with it did nothing! my yard is also extremely sunny so the pool ate chlorine like crazy, i need to replace the pump this year so i want to also switch to saltwater and cross my fingers that i dont have the issues i did last year. Im so confused on the type of pump i need and which ones come with the salt water and which ones have a seperate system and also which size filter i actually need to get, and any extras i have to buy along with it, any advice would be appreciated! thanks!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: need some help with a pump
    Welcome to tfp, nikic
    We can help you with your swg questions, but I am wondering if you had come to us with your problems maintaining the pool last year, your experience would have been better. Since maintaining a pool with and swg still requires knowledge of pool chemistry, might I suggest that you try it again this year with liquid chlorine/bleach before moving to the swg? We will help either way.
    Pool school is a great place to start, the link is always near the top right of each page. Maybe this article is a good one for you to start with: http://www.troublefreepool.com/pool-..._chlorine_pool
    If you do go with a swg now, then I would recommend not getting the pump/filter with the built in swg, since they never fail at the same time.
    Apr 2012
    SW Ohio
    456
    Agree 100% with linen
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    May 2013
    long island, ny
    2
    thanks, after reading a few posts i think i may skip the saltwater system for this year altogether, i still need a better pump, i know that the pool is pretty small but i would like to get one that is stronger then it actually needs to be, would this one be the best one to get for my size pool? http://www.amazon.com/Intex-650-Gallon- ... B002V1H11W
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    That would be a good one for you pool.
