Results 1 to 7 of 7
Thread: Jandy Aquapure 1400 with PureLink, codes 125 and 154
    Aug 2010
    New Caney, TX 77357
    184
    Subject codes are indicated on the PureLink display. I know 125 is "cell needs to be cleaned or replaced". It is clean, so not looking good. The cell is out of warranty, installed about 2 1/2 years ago.
    I can't find a code 154 for this equipment. I have a troubleshooting guide with voltages for the various test points, etc. but it is not for the PureLink model that I have. Maybe for an earlier model. I have Flow (per the display) and when the cell is On, the voltage at the cell is 37 VDC (measured by pulling back the power cable just enough to check with volt meter). The sensor went flaky last year and was replaced under warranty.
    What else can I do to confirm the problem is the cell before purchasing a new one? Not sure where to verify the exact model number PureLink that I have or where to find the appropriate troubleshooting guide.
    20K gal, inground with attached spa, pebblefina plaster (bella blue), flagstone coping, moss rock waterfall, Sundek - Indian wheat, (2) Jandy PHPM2.0 (filter pump and waterfall), Jandy DEV60 DE filter, Polaris 280 pool cleaner, Polaris Halcyon PB4-60Q booster pump, Polaris 1.5 HP Air Blower, (2) Jandy WaterColors LED lights, Jandy LXI400P Heater, Jandy AquaPure PLC1400 SWG, Jandy AquaLink RS PureLink Controller and PDA.
    Aug 2010
    New Caney, TX 77357
    184
    Re: Jandy Aquapure 1400 with PureLink, codes 125 and 154
    Buehler? Buehler? Buehler? Anyone?
    I've never heard of code 154.
    37 volts is high, which is consistent with the cell wearing out. How old is the cell?
    Aug 2010
    New Caney, TX 77357
    184
    Jason - it has only been in operation about 2 1/2 years.
    Jun 2011
    Long Beach, CA
    2,790
    Is this the trouble shooting guide that you are using, http://www.pleasurepoolsno.com/wp-conte ... Manual.pdf.
    I also never heard of code 154.
    How often have you needed to clean the cell? What is your average run time and % setting? It seems like an early worn out cell for some reason.
    Any chance you have a 3 year warranty? The sensor was replaced under warranty about a year ago, might be worth a call to Jandy. Worse they can say is no warranty, but they might also be able to help you with the 154 code.
    Aug 2010
    New Caney, TX 77357
    184
    Quote Originally Posted by ping
    Yes that's the guide I have.
    I cleaned the cell every few months. Have not logged that activity so don't know the exact interval. Average run time is around 12 hours per day. Setting has varied from 80-90% typically depending on the season.
    My understanding on the warranty is 2 years after install. Worth a call to them though to double check that and the 154 code.
    Thanks.
    May 2012
    Florence, AL
    20
    Something isn't right. 90% x 12hr pump run time means the cell is running 10.8 hrs a day. You shouldn't need to push it that hard on a 20k gallon pool. That particular cell is rated for a 40k gallon pool. I have the same cell on a 33k gallon pool. I run the pump 18 hrs a day with the SWG duty cycle set at 30% currently for 5.4 hours cell on-time per day. With water temp at 83 and ambient air temps in the mid 80s currently, my FC is right at 5.5.
    What is your CYA level?
    I run mine at 70ppm as recommended here. with the CYA at 40-50ppm as originally set by the PB, I had to run the cell twice as hard (50% duty cycle with the pump on 24hrs) to maintain the same or less FC.
    Running the cell that hard over 2.5 years may have just plum wore it out.
    33k Gallon IG Freeform Gunite built in 1989 - Renovated Spring 2012 with Diamondbrite Plaster and elevated spa converted to waterfall
    Jandy Aqualink PDA Automation & Control System - Jandy PlusHP 1.5hp Full rated Pump - Hayward 36in Sand Filter - Jandy Aquapure 1400 SWCG
    TF100 Test Kit
