Thread: Vinyl Liner Patterns
    I've been trying to decide on a vinyl liner pattern and I'm having a hard time visualizing the finished product. I was wondering if anyone has a pic of the Moonstruck pattern in their finished pool.
    Thanks in advance,
    KJK
    KJK
    IG, 16X38 Double Roman, 20,000 gallons, Pentair TA-60 Sand Filter, Waterway Chamption 1.0 HP Pump, SWG
    Jul 2011
    Monmouth County, New Jersey
    81
    Re: Vinyl Liner Patterns
    Picking a liner was, for me, the hardest part of the setting up the pool build. I finally picked one by filling our deep white tub with water and then putting the likely candidates on the sidewalls of the tub. The liners looked so different under the water. I also put the samples on a wall way across the room to see what the liner would look like from a distance.
    I love what I finally picked and I don't think I would have picked the one I have till I saw what it looked like in the water.
    Nancy
    Built in October 2011, 16 x 26 x 20 L shaped vinyl IG steel wall pool, Hayward DE pro grid verticle filter 4800 pool, Hayward two speed superpump, 120,000 BTU Pentair Ultra Temp Heat Pump, Aqua Rite Salt system, 8' wide walk out steps, 2 skimmers, 4 returns, 2 main drains, 500 watt underwater light, intermatic mechanical timer
    Thanks Nancy. That's a great idea!
    KJK
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    My PB told me that the darkness can/could make a difference in water temp. That may be because we are in the south and my pool is in full sun almost all day (SOME shade hits around 5-6pm. I chose a lighter liner for the less absorbent of rays to warm water. I still was trying to cool the water a good bit last summer because it was over 90 water temp. This may not really have any effect but that was what the PB reminded me of. I suppose that would also depend on your climate and sun/shade factors.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Apr 2013
    Long Island, NY
    19
    No pools your builder could take you to see?
