Thread: Intex - adding Hayward thru-wall skimmer PVC Thread question
    May 2013
    McKinney, TX
    2
    Hi everyone-
    Just found this site and really enjoy reading through all the information (and headaches) that people have shared!
    I am in the process of hard plumbing my replacement Intex filter/pump along with the Hayward Skimmer. The problem I have is that all of the threaded PVC connections are leaking....no matter what I have done.
    I read on the pvc connection manufacturers site, that I should NOT use Teflon tape, however I see other people are doing this. Others have suggested to use pipe dope and then there are some that say not needed or don't do it!
    Any suggestions on how to rectify this would be very helpful.
    Josh
    16'x48" 5000 gallon Intex pool, Intex 56673EG Filter hard plumbed with Hayward SP1091LX Dyna-Skim Skimmer. (Just ordering now...) TF-100...plan to transition to BBB method, however have been using tablets and shock from Leslie's til now.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Intex - adding Hayward thru-wall skimmer PVC Thread ques
    Welcome to tfp, Eyemalive
    Most likely you will need something on the threads to prevent leaking. I have successfully used 3-4 wraps of teflon tape, also using a thread sealant for plastic pipe can work.
    22,549
    Welcome to TFP.
    Linen has some good advice. I like the paste, but tape works too. If you get paste be sure to get the stuff that's for plastic piping.
