Thread: Intex Manual Vacuum - use pool water instead of hose
    dbaines's Avatar
    May 2013
    Mechanicsville, Virginia
    23
    I used my manual vacuum today and it worked fine.. the only problem I have with it is adding new water messes with the chemicals and wastes water (have to drain it out). So, I want to know if anyone has tried rigging up a connection to the pump outlet to push water through the manual vacuum, just like the garden hose? It would eliminate both of my problems with using the garden hose if I could use the pressure that is already created when the water is returned to the pool by the pump instead of the garden hose.
    We know we can upgrade the pump and get a real vacuum, but we have a 14'x48" pool that we don't want to spend much on as it's a temporary setup for the next year or two before it will be completely removed.
    Thanks so much for any ideas!
    DBaines
    Intex 14' x 48" Ultra Frame (4000 gallons)
    -Intex 2,650-Gallon Sand Filter Pump -Intex 1,000 GPH Filter Pump -Intex Deluxe Surface Skimmer -Hayward Above-Ground Automatic Pool Cleaner (Diver Dave) -Taylor Complete FAS-DPD Pool Water Test Kit K-2006
    dbaines's Avatar
    May 2013
    23
    Re: Intex Manual Vacuum - use pool water instead of hose
    I have the hose adapter to put on where the water is pushed back into the pool... then I just need to find a male tubing-male garden hose adapter to put on the vacuum and the tubing/hose.
    http://www.bluefade.com/intex-surface-s ... 7Aod0nEAMg
    maybe something like this for the vacuum:
    http://www.lowes.com/pd_22541-322-35041 ... _-11259695
    Any concerns on doing this or any ideas how to pull it off?
    Or maybe we'll just try one of these.. http://www.lesliespool.com/Home/Automat ... 57989.html
    Oct 2012
    Houston, Texas
    6
    I bought a Zappy, couldn't really get it to work with my pump and filter. I have a 16'x48" Intex ultra and was using a combo pump, filter and salt water system. I don't know if the pump just didn't get enough flow or what. I did and still do use the 1.5" flex hose that came with the Zappy to vacuum, so it wasn't a total loss. I connect the flex hose to the skimmer adapter, fits perfectly. I went out and bought a 16' pole and a vacuum head. I found that it vacuumed so well that I was having to change filters halfway through vacuuming.
    The next season I upgraded to a 14" Intex sand filter and pump combo. I tried connecting the Zappy to this new setup, no joy. Manual vacuuming is much easier with the sand filter as I don't have to stop and change or clean the filter cartridges any more. I do have to back flush the sand filter periodically and that does take water out of the pool. However, it is not enough that it throws the pool chemical balance off.
    I'm pretty sure you should be able to get some flex hose of sufficient length at any pool supply store as well as a pole and vacuum head. I actually bought the pole and vacuum head at Home Depot.
    Intex Ultra Frame 16' x 48"
    14" Intex sand filter w/pump
    Intex SWG
