Results 1 to 7 of 7
Thread: Hi, I have a couple of questions
    May 2013
    Westborough, Massachusetts
    6
    I'm new to the pool world, so I have a couple of questions I was looking for help with,
    Today's test--
    FC: 13
    CC: 0
    TA: 140
    CH: 120
    CYA: 90
    pH : 7.3
    Pool is clear.
    So, I know my CH is low, but I have a vinyl IG pool, so do I care? Should I raise it ?
    With my CYA on the high side, can I just balance my FC to a higher level? It looks like the chart says a target of 10?!
    Thanks!
    20k gal, IG vinyl, sand Hayward s-200
    30,432
    Re: Hi, I have a couple of questions
    You are correct on both counts. Ignore you CH in a vinyl pool.
    If you choose to leave your CYA at 90, you have already figured out where your chlorine needs to be....be sure to keep it up there.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Welcome!
    You are correct on both counts. Your pool doesn't care about low CH since it's vinyl, and you do need to maintain a higher FC due to high CYA. If you're using trichlor pucks or dichlor powder, stop it! You could use Cal-hypo if you wanted to, but why bother? Bleach doesn't add anything extra that you need to worry about.
    Sadly, you will be pretty much stuck to using the FAS-DPD tester for FC, every time. No quick check for you.
    The only fix is a partial drain and refill. You'll lose some CYA due to backwashing and splashout, but not enough to bring things down to 40-50 by the end of summer.
    May 2013
    6
    I'm just using BBB
    May 2013
    6
    We are on well water, so I was hoping not to have to drain 1/2 the pool..
    So, are there no other negs than balancing to a higher FC and using the FAS-DPD?
    Thanks!
    Richard320's Avatar
    Jan 2010
    19,074
    Quote Originally Posted by Amy21
    Thanks!
    If you do get an algae bloom, you'll be buying bleach by the drum, not the jug. It's just inconvenient to have to maintain it at that high a CYA. I've done it, and I don't recommend it because it is such a pain. But if you're on a well, you have good reason to live with it. If you water the lawns, use pool water instead, then put the water back in the pool. That will lower it a few PPM every week.
    May 2013
    6
    So, with vigilance, not letting the FC go below 10, I shouldn't get algae?!
    Good tip about the watering
    Thanks so much!
