Results 1 to 7 of 7
Thread: Awesome Opening
    May 2012
    Montville NJ
    545
    Awesome Opening
    Opened the pool this past weekend
    Last year when I closed it I ran the CL up to 13.5 ppm
    Opened it 8 months later, at it was at 11.00 ppm! Clear and sparkly.
    Of course then it rained buckets and that threw any kind of chemistry off. It's sitting at shock levels right now - passed the OCLT last night. Once that CL drops a bit I'll thow the new solar cover on.
    Hope everyone is having a smooth opening.
    We wont talk about the multiple leaks from the filter after I took it all apart and did a clean and rebuilt over the winter - but I will say the flow is now awesome, and the pressure is holding steady at 10psi.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Awesome Opening
    Great job opening
    Sorry to hear about the leaks, but it sounds like you got out in front of that!
    May 2012
    Montville NJ
    545
    Re: Awesome Opening
    Thanks
    There were three little leaks.
    One around the bump shaft - went to the pool store and they sold me the wrong O ring, so a good dollop of lube solved that.
    One at the air vent. I am thinking there should be an O-ring or flat washer there, but the parts diagram does not show one - so again, lube tothe resuce
    Third leak I have not tracked down yet. slow drop (like one drop every 30 seconds) when the pump is running. Either it is through the threads on the return line (easy) or a hairline crack that is in the top of the filter housing (not so easy). This weekend I will play with it - when I also plan to hard plumb the filter (you would think I would do that BEFORE opening, but nope, not how I roll)
    -dave
    Zodiac Wahoo
    Apr 2013
    Central Massachusetts
    174
    Re: Awesome Opening
    Very nice Dave.
    Where are you located? I'm just curious if its possible to ever have a successful opening like that in my climate (New England) where the pool is closed for 7-8 months of the year.
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Awesome Opening
    You're done SLAMing when:
    May 2012
    Montville NJ
    545
    Re: Awesome Opening
    I'm just south of you. Northern NJ to be specific. My pool was closed for 8 months. I cleaned it well before closing. Made sure I had no problems for a week before closing (I loose 1 ppm of CL on a normal day. I made sure that did not change) I ran the CL to 13.5 before closing and then drained to just below the skimmer.
    Dave
    Zodiac Wahoo
    Apr 2013
    174
    Re: Awesome Opening
    Awesome indeed then! I hope I can have success like that next spring with the help of the fine people on this forum!
    My Build thread
