Thread: Weekend Away - How to Leave the Pool
    I bought a house in November with an inground pool and opened it up last week. Details in my sig. This is my first experience maintaining a pool, but the forum here has been a great help. It's finally clean, clear, and on the way to being a swimmable pool (still a bit cold ~ 65 F).
    I need to go away for the weekend. Just two and half days.
    How should I leave the pool? Shock, cover, set the pump on a timer to run X hours per day? We're getting a lot of leaves and maple "helicopters", so I'm worried about the skimmer getting clogged. It was pretty clogged up after the storm last night. I do have separate lines with shutoff valves for the skimmer and the bottom drain. Should I close the skimmer valve and let the pump draw just from the bottom drain? Can I just leave the pump off while I'm gone?
    in-ground 20'x40' rectangular pool; 27,000 gallons; Hayward EC-65 DE filter; vinyl; Waterway 1.5 HP, 3450 RPM pump; Levels tested with a TF-100; Location: NW Indiana.
    38,248
    Re: Weekend Away - How to Leave the Pool
    Welcome to TFP!
    Raise the FC up towards shock level and put a cover on and you will be fine. Best to have the pump running for at least a few hours each day and leave both the skimmer and floor partly open.
