Thread: winterize a intex metal frame pool
    i live in long island ny and have a 16x52 inch intex metal frame pool and i would like to winterize it like a normal above ground pool intex saids to drain the pool dry it and store in a place obove 32 degress in the swim saids it is ok to witerize it and cover the pool is it ok to witerize it being that my area for some months dosnt get out of the 40"s
    Re: winterize a intex metal frame pool
    I have done this for 4 years. Just drain the pool by at least a 1/3. I live in Buffalo so we have similar winters. I did winterize with tons of bleach and 2 bags of shock beforehand.
    ProSeries Above Ground 20x4 Sand filter 1 hp
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    578
    Have left our newest one up two winters now. Granted here in Oklahoma it doesn't stay freezing for long but it has frozen around the sides. The pump stays running all winter. Farther north it'd be ideal to drain below the lowest opening and cover or periodically check the chemicals so it doesn't turn green once it warms up. But these pools are pretty resilient.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
