Thread: Main Drain Repair
    stevenm's Avatar
    Sep 2012
    Camillus, NY
    27
    Main Drain Repair
    Hi all!
    Now that we're back into pool season, we're looking to repair our main drain, which we lost in a rather awful liner replacement experience with a local PB (seriously, you didn't pressure-check the lines?! ).
    Anyway, we've begun the dig and uncovered the lines, along with some interesting buried concrete work (more on that later). None of them pressure-check below the frost line unfortunately. Anyone have any suggestions on how to proceed?
    On to the pictures!
    Day 1: The digging begins!
    Day 2: Further down the rabbit hole.... (now we can stand under the pool deck!)
    See that concrete down there? Surprisingly, the pipe doesn't come out the other end - it disappears into the concrete. Upon further excavation under the concrete, we found an older pipe embedded in the concrete running back towards the pool wall, perpendicular to the visible black pipe the runs into it. Any thoughts about this?
    Will update with more as we progress! Any help would be appreciated.
    27,000 gal. vinyl in-ground pool w/ 1.5" piping, 1 HP Pentair SuperFlo pump, Hayward Pro Series sand filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Main Drain Repair
    Better you than me!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I don't know your soil conditions, but I would strongly recommend you stay out of that hole. It looks extremely dangerous to me. You have thousands of gallons of water on the other side and you are removing the support for the wall.
    stevenm's Avatar
    Sep 2012
    Camillus, NY
    27
    Quote Originally Posted by JohnT
    Mostly a lot of clay and heavy packed dirt. I'm in upstate NY, so we've got pretty good soil compared to some other places I've seen on here.
    I do see your point though. Any other way to go about this that would be safer, or should we just give up and move on with just the skimmer?
    Jan 2013
    The Great State of Texas
    243
    Do you need the main drain? My pool had the main drain sealed years ago. I have to agree that getting in that hole seems pretty scary to me... although I have done my share of "hey, somebody hold my beer and watch this" type things in my life.
    ~18,000 gallon
    DE filter/chlorine
    IG Grey Plaster
    25 year old pool w a facelift in 2014
