Thread: Calcium Hardness
    Mar 2013
    CT
    353
    Calcium Hardness
    I'm confused as to why this test is necessary. Does the hardness affect any of the other chemical components one way or another?? If I'm getting 140 on a calcium hardness test isn't that ok?? Why would I want to make my pool water harder.
    Also, how often would I want to test for calcium hardness?? Is say once a week enough??
    Thanks!!
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: Calcium Hardness
    Quote Originally Posted by dschribs
    Thanks!!
    Sent from my Samsung Galaxy 10.1 using Tapatalk
    For your pool, low CH is no problem. But high CH can lead to scaling, and you can't attack it with a steel brush. If you're only at 140, I'd suspect you don't have hard water, so every couple weeks ought to be plenty.
    30,432
    It's important to make sure in a vinyl pool you don't have too much CH (you don't)
    It's VERY important in a masonry pool to make sure you don't have too much or too little. Too little in a masonry pool can leach calcium from the masonry.
    CH is pretty darn stable and I would say testing 3- 4 times in the swim season is certainly enough.
    (Richard320 beat me)
    Mar 2013
    CT
    353
    We just moved into the house and as my wife said after her first shower. "The water seems very hard here". I will keep an eye on it every few weeks. Local pool store wanted me to raise my hardness. Go figure...
    Richard320's Avatar
    Jan 2010
    19,067
    Of course!
    Hardness Increaser is a high markup item.
    So's Alkalinity Increaser - baking soda at 4X or 5X the price you can buy the exact same thing at Costco, but Costco's doesn't come in a spiffy plastic pail.
    Mar 2013
    CT
    353
    I'm begining to understand...its all finally sinking in now...I see the light as they say!
