Thread: Leaking pool Help!
    Leaking pool Help!
    Trying to figure out the next course of action for us. We had someone install our 24ft AGP on May 15.. Everything seemed to be going okay, was getting the pump wired up and adding our chemicals. Kids playing in the pool May 25, 26, 27. And then I noticed the problems. Tuesday, the 28th I get home from work and I go outside to finish laying the bonding wire and I notice the dirt is becoming saturated on one quarter side of the pool.
    Next morning and there is about 1 inch of standing water in spots. I can also see the frame starting to buckle in 2 spots close to where I assume the leak is near.
    It would cost someone $125-150 to come out and find the leak and patch it. Or we could spend around $250 for a new liner, or try to get ours replaced under warrantee.
    I was at work and my wife thought it might be leaking from the skimmer or return cutout so she drained it below the skimmer.
    We are supposed to leave for vacation in 4 days and I’m wondering should I drain the water before then. We talked to the installer but he said he was going to try to come out and take a look next week sometime while we are gone. I assume he is just going to say its not his responsibility anymore since it was up and not leaking for 2.5 weeks after his work was done.
    I will have pics up in the morning after I see if there is anymore leaking.
    What’s the next course of action??
    24FT Round AGP @ 14K gallons. Waterway 1.5HP Pump with Sand filter.
    Re: Leaking pool Help!
    Here are pics of the problems with the wall.. I believe I have found the hole in the liner, assuming it's only one.
    22,550
    What does the hole look like?
    I'd just get a patch kit and patch it. You can patch it under water so there's no need to drain it.
    Bummer, but those things happen.
    Hole is really small. Probably smaller than the diameter of a drinking straw. The water draining through it formed like a little crater with the hole in the center. That is how I was able to find it visually. Did the dye test and confirmed water was leaking from that point. My concern is the wall buckling in the 2 spots.
