Thread: Seeking Advice on Calcium Build Up
    Split from seeking-advice-on-calcium-build-up-t60244.html
    Please start your own thread when you have a question or need help! Butterfly
    Please help! I'm new to site and desperate. For the third year now, we have opened our gunnite salt water system pool to massive amounts of scaling. Last year was so bad kids were bloodied each time they went in. Had to drain entire pool, acid wash and diamond buff at a cost of $3,000. Noone seems to have an answer for us. We use professional pool company to open and close pool properly and maintain pool all summer in pristine condition. Just opened pool and same exact issue!! My husband is ready to fill pool in. We have a soft cover and city water. Any advice would be soooo appreciated!
    30,420
    Re: Seeking Advice on Calcium Build Up
    Calcium scale is almost always the result of allowing your pH to be too high and stay too high. Can your post test results for pH, TA and CH?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Yep. High pH, high TA, and high CH are a bad combination. If you use Cal-hypo "shock" to chlorinate, it's even worse.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    419
    Also many fill/ top off their pool from wells and or city water that may contain lots of minerals that add to the scaling.
    Always use at least a filter on your hose for pool top offs and refills.
    And you must be getting PH creep - needs to be managed on a daily basis until it becomes stable.
    Rainwater increases PH as well.
    My friend had a similar problem until I took over his pool and started testing and balancing his water - as well as brushing and cleaning the pool--- and no more well water top offs.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
