Thread: Any Advise on Surface Clearing Skimmer?
    Mar 2013
    Phoenix
    10
    Hello,
    My pool is near a couple of trees and we get tons of little leaves, pine needles, pollen that float on top of the pool. We've only got one suction port for skimming/vacuuming so I was hoping someone could recommend a product to allow us to do both. I've seen some floating skimmers that hook into the vacuum and can be used in connection with them but I just don't know if they would help. I've also seen the Vac-Mate by Pentair which allows you to skim and run a vacuum at the same time supposedly. Any advise would be appreciated!
    Mark
    12k kidney shaped inground plaster pool, single speed pump with no timer, sand filter, and barracuda scrubber guy.
    Re: Any Advise on Surface Clearing Skimmer?
    Poolskim-- I also have trees near. I've hooked up 2 Poolskims and they are doing a great job!
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
