Results 1 to 7 of 7
Thread: First time opening
    First time opening
    Hi ,
    First time opening - in ground vinyl lined - 28,000 gal - cartridge filter, HAyward pump. Everything went back together fine, but when I started up the pump to circulate, the hose that is hooked up between the pump and the filter (used for draining water) was draining water. When I tried to close the valve so that the hose line was closed, I couldn't locate the right position. It seemed that something changed since the previous year, as I cannot close that side of the valve. Does anyone know why this could be the case?
    23500 in-ground plaster
    STA-RITE S7M120 filter
    FAFCO Solar panels and Model 303 controller
    Letro Legend Pool sweep
    38,301
    Re: First time opening
    Welcome to TFP!!!
    Please add a picture of your equipment and plumbing so that it is more clear what you are talking about.
    What would be the best way to do this - the pictures exceed the attachment size limit. It also won't let me paste in this reply?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Quote Originally Posted by AMH
    Resize and add attachment or use flickr/ photobucket/ webshots / tumblr
    Thanks - I resized and attached 3 pictures
    38,301
    The off position of the valve is on the opposite side of the handle (should actually say OFF or CLOSED). I think you just need to rotate the valve 180 degrees to close off the waste pipe.
    It will not let me turn it all the way to that position. I am not sure why this is the case as I did not have any issues with this valve last season. Pool company closed for us last season, so I am not sure if they changed something, etc. All I did was reconnect the pipe at the pump connection.
