Thread: High CYA; how much to drain?
    May 2013
    Frankfort, Ohio
    1
    Split by moderator. Please start a new thread for our own questions. Thanks, jblizzle
    My cya level is 132, when I have the water tested at the pool store it says it is ideal between 30-200 but my fc is 0. From what I'm reading it sounds like I need a partial drain, how much is considered a partial drain?
    23k gal, IG, vinyl,sand filter, 1/2 hp Hayward, 2007 install, Hayward tiger shark
    38,301
    Re: High CYA; how much to drain?
    Welcome to TFP!!!
    First, we do not trust pool store testing ... especially for CYA.
    If you would like to learn our methods, read Pool School and order one of the recommended test kits so that you can fully understand what is going on in the pool.
    Lowering CYA is a 1 to 1 reduction with the volume removed ... replace 50% of the water and your CYA will go down by 50%. If you do not have a SWG, then our recommended range is a CYA of 30-50ppm.
