Results 1 to 9 of 9
Thread: divingboard cleaning
    May 2013
    Mckenzie, Tn.
    19
    What is the best thing to clean my 10 year old divingboard with?
    18'x32'x8' in ground, 300lb sand filter
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: divingboard cleaning
    Welcome to TFP!
    What's on it? Stains from leaves, rust, ___?
    May 2013
    Mckenzie, Tn.
    19
    No rust...mainly dingy!
    May 2013
    Mckenzie, Tn.
    19
    I have used super clean in the past but I hate to get it in the pool. I guess like bleach mix would be best...
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    I have used a bleach/water mix of roughly 20-25% bleach along with a nylon bristle brush followed by a plain water rinse from a garden hose.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Quote Originally Posted by Blackbeard
    A teenager. Maybe even a Tweenager.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by Richard320
    Yep, have to admit that is a better solution
    May 2013
    Mckenzie, Tn.
    19
    Thanks! My teenagers are not that any more...I guess I will use the brush, bleach and myself method! Thanks so much!
    May 2013
    Mckenzie, Tn.
    19
    Oh yeah! It brightened it up...thanks so much!
