Thread: Cleaning algae out of my just drained above ground pool
    How can i get all the algae out of my pool?? I have a 16x48 intex AG pool & just the cheap water hose vacuum b/c the pump isnt strong enough for a good one. We just drained the pool & we have about an 1in of water & all the nasty algea & bugs we need to clean out, what is the best way to clean this out?? i thought maybe a wet vac but Im not sure. please help
    AG Vinyl Intex 16ft 5,000+ gal
    cartridge 1500 FR
    All new to this pool stuff
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,640
    Re: Cleaning algae out of my just drained above ground pool
    I'm thinking push broom it into a bailing bucket for safety sake of the liner. Wet/dry vac may be too much for it.
    May 2012
    NW PA, halfway between Pittsburgh and Erie in the PA snowbelt
    159
    Prior to my 22' Intex that I left up last year, I drained all my smaller ones every year. I didn't take them down but would leave about 2-3 inches of water in the bottom for weight so it didn't get blown away. When that 2-3 inches of water thawed in the spring I had all kinds of **** in the pool, water, leaves, dirt, dead bugs, pine needles, anything that would get blown in over winter. I used a shopvac every spring to suck up the water and gunk in the bottom.
    I would put the shop vac on a milk crate and thread the bottom drain cover of the vac on loosely, just enough to prevent the stuff from coming out and to get a good vacuum on the hose. Then I could just twist the cap about 1.5 threads and it would drain out.
    After sucking all the water out, we would scrub the entire surface with bleach and rinse it out with the hose. Fill with water and swim. We didn't do much more than float a puck around in the water back then. The smaller pools, we drained and refilled several times through the summer since they were small sized.
    I did this with my last 4 pools until this past winter where I actually winterized the 22' Ultra Frame and left it full (right below the skimmer port) all winter.
    Mike
    22' round Intex UltraFrame pool, Intex 633T 2500gph paper cartridge filter/pump
    with broken Intex SWG, using bleach this year
    TF-100 test kit
    Thanks for the info. Just used the shop vac & it worked like a charm. I used a beach towel & wiped all the walls & floor down & filled her up. Now its time for some swimming
    cartridge 1500 FR
    RubyLK's Avatar
    May 2013
    Michigan
    16
    Hey Mike,
    I am curious about your winterization of your pool? I see this post is from May 2012. Did you do this (leave the pool out) 2 winters in a row now? Everything work out okay? You said the water left in the pool just froze over and all was well in the spring, no holes or other issues? I was a bit scared to do this with my 26 x 52 ultra frame, but I know it all depends on where you live, and also what kind of winter you get. I'm in Michigan. Do you live somewhere warm and is that how you pulled this off? Very curious about this. It was my assumption the liner would crack from the ice (like a can of pop left in the freezer too long) and the poles would rust if left out all winter. Did you put a cover on it during this time or a tarp at all? What about snow building up on top?
    Thanks!!
    Ruby
    Intex Ultra Frame 26' x 52" round pool. Gorilla Pad, Intex 2650gph Sand Filter Pump, seperate Intex Saltwater System and Skimmer Basket. Newbie pool owner, in my 2nd season! :)
