Thread: Running SWG/Pump
    May 2012
    Houma, LA
    104
    Running SWG/Pump
    I have a Kreepy Krauly E-Z Vac that I really like.
    Should I turn off the SWG when the Vac is connected and running?
    Sharkline 18'X40' Matrix 54 AGP(21k gallons), Pentair Sand Dollar Filter System with 1-1/2HP Dynamo, 125 lbs of ZeoBest., Hayward AquaRite SWCG w/T-Cell 15 TurboCell, Confer Plastics STEP-1 Easy Access Above-Ground Pool Steps, TF-100 Test Kit
    Re: Running SWG/Pump
    The Kreepy Krauly E-Z Vac is a suction side pool cleaner, so it doesn't really care if the SWG is on or not. That is an issue that can affect pressure side cleaners.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    That's a suction side vac so shouldn't hurt to leave the SWG on, as long as you have good flow.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    May 2012
    Houma, LA
    104
    Thanks guys. I was jsut making sure that I was thinking correctly. I'm more worried about the flow sensor than anything. But the sensor being on the return side, it' shouldn't be effected.
