Thread: rain rain go away..
    rickyislandgirl's Avatar
    Apr 2013
    Cedar Lake,IN
    58
    rain rain go away..
    Since it has been raining like crazy here the water is to the top of skimmer do I need to lower my water level??
    Thanks
    10,400k, AG 21 round, 1.0HP Waterway pump cartridge filter. TF-100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Re: rain rain go away..
    Quote Originally Posted by rickyislandgirl
    Thanks
    I would. Otherwise it will overflow and oversaturate the ground beneath the pool, which vcan cause the sidewalls to sink in and throw the pool out of level.
    Stick a garden hose or the vacuum hose in the pool, feed it in slowly so it fills, cap it with your hand somehow, then haul it out fast and get it below the water level in the pool. That will start the siphon. Haul a lot more hose out fast to really get it going, then direct the flow somewhere away from the pool.
    22,550
    I use my vacuum hose with the head attached. That way the hose won't slip out of the pool when you pull the hose over the wall full of water.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,607
    I either just pump it to waste or vacuum to waste if it needs it.
    Apr 2013
    Cedar Lake,IN
    58
    thank you!
