Results 1 to 20 of 20
Thread: another cloudy pool with good numbers
    I've read through a few posts here with similar issues, but I think the difference I'm having is the pool is keeping chorine.
    Numbers Monday according to pool store, over 24 hours after adding chemicals, compared to my numbers with the Taylor K-2006 if different:
    FAC 3
    TAC 3
    CH 310 I was showing closer to 550, but this is the first year I've used the kit
    CYA 45, I was showing closer to 30 with cloudy water (I could still very faintly see the dot when water was up to the top) . I've put a few pucks in a floater to bring up a little bit.
    TA 90
    pH 7.6, I showed 7.4
    When I got back I proceeded to shock the pool up to 15 with 8.33% bleach and have been keeping it there since, with the lowest I've measured being 12. It's now almost 2 days later and I still can't see the bottom except in the shallow end, and that's not clear. The pool is a good color - just not clear. My pump doesn't show pressure but I've backwashed about every day and a half when the Polaris stops moving and the jets slow down. I've noticed a small difference since starting the shock on Monday, but not much.
    Pool was dark green when opened 8 days ago. I had added clarifier late last week but not since since I may have overdone it, adding about 32 oz. over 3 days.
    Is this most likely:
    - a problem with the filter
    - possibility of too much Calcium despite pool store measure
    - just bleached dead algae still hanging around and I just need patience
    - something else
    Last year and this year the Polaris is picking up small amounts of sand.
    We've lived here 2 years and haven't changed out the sand in the filter, the previous owners lived here 2 years and didn't leave any records. Before that previous owners were good about keeping up maintenance but Leslie's doesn't have their records.
    Thanks for your help!
    1) 20K gallons 2&5)Tagelus Sand Filter TA60D, 60 gallons/minute
    3inground 4)gunite
    6) installed 1984
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: another cloudy pool with good numbers
    A couple things.
    One, you're doing well to maintain shock level.
    Two, trust your test, not the pool store
    Three, stop backwashing so much. Sand filters actually work a little better when they start to get dirty. Hold off on backwashing until the return flow is noticeably less or the pressure rises 25%. If it's 12 PSI after a backwash, wait until it goes up to 15 and so on.
    Four: be sure the main drain has some flow. If you don't have a drain or you're unsure how to open it, aim one of the return jets down at the deep end to stir up that stuff so the filter can grab it.
    Five: if things don't improve in a day, you're probably a candidate for adding diatomaceous earth to your filter. We'll cover that later, if needed. But it might not be a bad idea to ask around now to see if any friends or neighbors have a DE filter, because you don't need much and a twenty five pound bag will last you a lifetime.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I suspect dead algae, sand filters can take longer to clear it, you might try a little DE in the filter to clear faster. Be sure to brush the pool as algae can form a protective layer that brushing will break down.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Thank you! Now that you mention it I remember my husband saying last year that the drain at the bottom of the deep end didn't seem to be drawing water. Everything was great then so I didn't really think about it. I will look into this more, also the DE.
    3inground 4)gunite
    6) installed 1984
    I've been out of town most of the last week. Still running the pool with same results. Slightly clearer but still can't see bottom in deep end. Talked to 2pool repairmen (one came by when I was gone) both say we probably need to replace the sand in the filter since this should be done every 3-5 years, we've lived here 2 and we don't know when it was done last. They don't use DE. Cost of 2-300 dollars and they're both booked awhile.
    Could my husband do this if he gets a few hours to spare? Any other suggestions?
    Thank you!
    3inground 4)gunite
    6) installed 1984
    30,419
    Run as fast as you can from those two repairman. Sand virtually never needs to be changed but it may need to be cleaned a bit. Open up the filter and inspect the sand bed for debris, crusting. It'll be easy to see if the sand is in good condition or if you need to stick a hose in it and clean it up.
    Save that 2-300 for Happy Hour!
    Richard320's Avatar
    Jan 2010
    19,000
    Quote Originally Posted by mau
    Thank you!
    Sand doesn't wear out. A deep cleaning followed by http://www.troublefreepool.com/pool-..._a_sand_filter ought to fix you up.
    Have you figured out the main drain yet?
    Apr 2012
    Puglia, Italy
    133
    Talked to 2pool repairmen (one came by when I was gone) both say we probably need to replace the sand in the filter since this should be done every 3-5 years.
    Thank you!
    I'm no expert but my understanding is that the sand should NEVER need replacing. We have had our pool 5 years now, and this year we did have the sand topped up, but not replaced. Explanation given was that you do loose a little sand when you backwash, so it does need topping up, but not replacing.
    I'm sure the experts will be along very shortly to agree (or not ).
    See, they beat me to it.
    400,000 Litre in ground infinity pool, with 40,000 litre holding tank (116 235.703 04 gallon). Vinyl liner.
    Two Astralpool Cantabric sand filters, 900mm diameter, each with 550kg of sand.
    Two ESI MP6 1.5kw 3 phase pumps.
    Still haven't figured out drain ...the repairman said you can't always feel the flow. I haven't been able to talk to him directly yet to discuss.
    Is the pool safe to use if numbers ok? I haven't been.
    3inground 4)gunite
    6) installed 1984
    Sep 2009
    Greentown, IN
    914
    If your pool is not clear and you haven't passed the overnight chlorine test it is not yet safe for swimming. Keep that shock level up and read through pool school again.... about the shocking process. It will give you all the details about how to know when you are done shocking.
    You may need to rinse your sand in your filter as others have suggested. Just be gentle with the laterals and components inside as you don't want to break anything.
    Adding DE to your sand filter is sometimes a big help when you just can't get that water clear. We opened to a green pool this year and I was getting annoyed with how long it seemed to be taking to get rid of the last bit of haze in the water. Went and got some DE and I'm gaining ground faster.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Flock it.
    38,285
    Quote Originally Posted by philly23
    Flock it.
    We rarely ever recommend the use of floc as it can cause more harm than good ... and just should not be needed.
    Thank you all for your advice. As an update, I was out of town for most of the last 2 weeks and couldn't get my husband or any pool guy interested in rinsing out the filter or adding DE. Kept the pump running and when I got back last Friday I could actually see the deep end drain although water was still cloudy. Unfortunately due to an unrelated electrical issue the pump had been off for over 24 hours. Got that fixed (off for about 40 hours total), added some clarifier and shocked the pool again last night to get rid of any algae that might have developed while pump was off. Water looks even clearer. Chlorine level is still at 12. When the chlorine gets down to a safe level, I'm assuming it's OK to swim again although it's not quite crystal clear.
    Looking at other threads on here I may look at an alternative to our mesh safety cover next winter.
    Thanks again! I have a few other questions which I'll post separately if I can't find a related thread.
    Latest numbers:
    PH 7.6
    TA 80
    Calcium 400
    FC 12
    CC between 12 & 12.5
    CYA 45
    3inground 4)gunite
    6) installed 1984
    38,285
    Are you saying that your CC are 12ppm and the FC was 12ppm? Making the TC = 14ppm?
    Either way, since the water is cloudy, you should review the Shocking Your Pool PROCESS and do it correctly to confirm nothing is in the water. IF the CC are that high (and not a typo), then you certainly need to do this. But I would at least make sure you raise the FC up to shock level of 18ppm and perform the OCLT (if the CC are actually 0.5ppm or less)
    30,419
    Please keep your questions under this thread. It helps us help you much better.
    Sorry, just rechecked that. CC was .2. I'd been adding those numbers to compare my numbers with pool store. That was actually TC. And I should have mentioned the pH, TA, and Calcium Hardness numbers were from before I started the shock.
    3inground 4)gunite
    6) installed 1984
    hawkeye's Avatar
    davenport,iowa
    118
    Id bump that shock level up to 16ppm....been there done that fixed it twice already
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
    Thank you to everyone with your help with this! We'd been swimming and happy for the past 2 days when the pump stopped working again.
    Unlike when we had the electrical issue last week when it was completely dead, the motor is running but there is no flow. It was fine this morning, my husband & kids were swimming this afternoon when my husband noticed there was no water coming out of the jets. I never did clean out the filter, mainly because I couldn't figure out how to do it from the manual and we were just happy to get into the pool for now.
    Could the filter be clogged and causing issues? Or could this just be from running the pump almost 24/7 the past 4 weeks?
    I'll get someone out to look at it ASAP, just wondering if anyone had any ideas.
    Also, what's the best thing to do when the pump's not working? I assume I should keep adding chlorine - what's the best way to spread it through the pool? I guess I'll have to shock again if it's not fixed tomorrow. Thanks! It's a Extreme E Emerson 1 HP pump.
    3inground 4)gunite
    6) installed 1984
    Richard320's Avatar
    Jan 2010
    19,000
    Is it making noise, just not moving water?
    As far as maintaining FC, adding it then brushing the pool should keep it mixed up. Don't let the Fc drop and you won;t need to worry aboyt the shock process.
  20. Back To Top    #20
    Yes, it's making noise but not moving water. And it must have happened pretty suddenly because it was great about 2 hours earlier. We don't have any kind of pressure gauge.
    3inground 4)gunite
    6) installed 1984
