Results 1 to 8 of 8
Thread: Baking soda causes SWG to say to much salt?
    I put some baking soda mixed in a bucket through the skimmer the other day and about 30 minutes later noticed my aqua logic saying the salt level was to high. Is their a reason behind this? Should I turn off the SWG when adding baking soda through the skimmer? I turned the percentage to 0 then turned it back to my normal operating percentage a few minutes later and the message was gone.
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
    38,237
    Re: Baking soda causes SWG to say to much salt?
    We do not recommend adding any chemical into the skimmer ... problem solved
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Ditto
    Ok so just pour infront of a return?
    11,969
    yep
    22,539
    Most swg's use conductivity of the water as an extrapolation of the salt level. Since baking soda is sodium bicarb, passing a concentrated mixture of it through the cell could cause the cell to temporarily read the salt level higher than it really is.
    Ok thanks. On a side question. My TA was 50. I added baking soda to raise it to 70 but had to add MA soon after to adjust PH so TA is now 60. Should I leave it and let it rise normally or add more baking soda to raise?
    38,237
    TA would only rise if your top-off water had high TA. I would just leave it. The lower TA may help stabilize your pH, or at least slow the rise.
