Page 1 of 2 12 LastLast
Results 1 to 20 of 37
Thread: First test results
    May 2013
    Pittsburgh, PA
    23
    First test results
    4 YEARS LATER I HAVE NO IDEA WHAT I'M DOING STILL BUUUUUUUUUUUMP CITY, PLZ GO TO LAST PAGE
    Did my first test with my brand-spanking-new T-1000 had some slightly confusing results:
    FC - 0
    TC - 0
    CC - 0
    PH - <6.8
    TA - solution was immediately red after adding the two drops of R-0007, and then adding the five drops of R-0008... lolwat?
    CH - solution turned purple immediately after R-0011L, then I followed and added 10 drops of R-0012 and there was virtually no change... lolwat?
    CYA - 50
    First step is to rock the shock to about 20 yeas?
    Then what? Can I add the baking soda and borax at the same time? Wait until my rock the shock treatment stays even keel?
    15k, AG, 1HP powerflo matrix, CC1500 cartridge, aquapro600 heater.
    38,235
    Re: First test results
    See: extended-test-kit-directions-t25081.html
    Your TA is at/near 0 and your pH is VERY low ... this should be the first thing you should deal with.
    You should add baking soda to get the TA into the recommended range ... then adjust pH as required into the low 7s ... then start the shock process.
    The CH does not really matter right now and you can figure that out later.
    Are you still using the Nature 2 minerals (not recommended) and/or trichlor pucks/sticks (likely cause of the crashing pH and TA)?
    May 2013
    Pittsburgh, PA
    23
    Bah, I hate that I got noobed with a link haha. Lets just say that before this post an idiot friend jumped in impatiently and dumped about 3 gallons of bleach and a 1 pound bag of shock in my pool, would that change my ability to add the baking soda?
    I actually ended up leaving the nature 2 minerals out of the equation, should change my sig I suppose.
    38,235
    The pH test will read artificially high if your FC > 10ppm. But that will not impact your ability to raise and test the TA. I would do that and let the FC drop below 10ppm and get the pH dialed in ... then go back to the shock process.
    May 2013
    Pittsburgh, PA
    23
    Word. Thanks.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I recommend you add have the amount of baking soda the pool calc calls for. Let it circulate for several hours, then test again, readjust as needed...
    May 2013
    Pittsburgh, PA
    23
    I added 8lbs and I'll check it tomorrow, getting a little late tonight. Thanks for the help internet friends!
    May 2013
    Pittsburgh, PA
    23
    I meant to ask last night, is there a resource or list that you pull this order of steps to take from?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by blackatom
    The Moderators and Experts have discussed a flow chart in our private lair, and sadly, haven't come up with anything. There's just too many variables. And also a lot of resistance to self-testing and conflicting information from the guys with buckets o'cure to sell.
    Some examples:
    pH is usually the first thing to adjust. But in your case, the lack of any TA will make adjusting pH difficult and it will swing wildly without enough TA to buffer it. Normally TA is too high but adjusting it is the last thing to do. Your case is different. Don't you feel special?
    If someone has Astronomical CYA or CH, there's no point having them adjust FC or pH because they'll need to start by draining water and refilling it with fresh, and treating water only to dump it down the sewer an hour later is wasteful.
    A month or so of hands-on and reading threads here will lead you to understanding. In the meantime, you can concentrate on consistent testing and asking questions.
    May 2013
    Pittsburgh, PA
    23
    Quote Originally Posted by Richard320
    Some examples:
    Appreciate the quick response. I definitely thought I was going to get noob linked like "dude it's right in front of your face" ha.
    What could be some of the causes for my TA to be so low? I love the idea of self-testing, I've seen enough knuckleheads in my industry making million dollar decisions about coatings without really understanding what they are doing. As far as getting pool stored, it might not be lack of knowledge on their part just hunger for money. Not that there is anything wrong with that, I'm just not going to have it be MY money.
    "Hey Mr. Pool Store Owner chemical seller dude guy, could you test my water and tell me what I need to buy from you so I stop having to buy things from you?" Does not compute.
    Richard320's Avatar
    Jan 2010
    18,967
    Dichlor and Trichlor - the pucks and powders the pool store pushes in you - are very acidic. They lower pH and TA.
    May 2013
    Pittsburgh, PA
    23
    FC - 0
    TC - 0
    CC - 0
    PH - <6.8
    CYA - 50
    Alright. Followed the pool calculators instructions, gradually added baking soda, retested about half an hour ago.
    Didn't get anything on the quick Chlorine test, so I figured I'm at zero, not really worried about that quite yet as I understand.
    TC - 0
    PH - < 6.8
    TA - 100
    CH - Didn't do as I read it doesn't matter too much right now anyway.
    CYA - 50
    So I went back to the calcamalator and it told me to put in 5 boxes of borax to get from 6.4-7.5. Yeah wasn't exactly prepared for that, but I did add the 3 boxes I had. Will test tomorrow around 5pm, then I'm assuming I will be running out and getting more borax. Once I get the pH where it needs to be, I do another full test, make sure everything else is in line and then start the shock process. Shock that **** until my pool meets linens 3 criteria. Then I can go swimming in the buff yea?
    38,235
    Even just get the pH to 7.2 or so and start the shock process.
    30,401
    +1 what jblizzle said......getting to 7.2 is adequate and you may not have been as low as 6.4.
    I re-read the shock process up in Pool School and could not find that as part of the instructions ......TFP neither endorses nor rejects that step but, PLEASE, PLEASE no pictures!!
    May 2013
    Pittsburgh, PA
    23
    Yeah I actually did have my water tested by a pool store when I first opened up the pool which was before I got my T-1000 and considered my relationship with the pool store... terminated.
    Hey you never know what might [s:zq10h11u]pop-up[/s:zq10h11u] happen!
    38,235
    Careful ... Richard might "borrow" your picture for terminating the pool store relationship.
    May 2013
    Pittsburgh, PA
    23
    TC - 0
    PH - < 6.8
    TA - 100
    CYA - 50
    Tested when I got home from work today ~5:30. Even after adding 3 boxes of borax last night, pH didn't seem to want to budge.
    TC - 0
    pH - < 6.8
    TA - 130
    CH - Nosir
    CYA - 50
    Added another 5 boxes of borax, calculator said 5.7. Pool gods, when should I be able to test again for pH? I would love to do it right meow so that I can rock the shock tonight!
    EDIT: Also, my brand-yeah-daddy-spanking new filter got here today, and also my pressure gauge was broken, and I replaced that too. I'm running around 17psi, sounds good yeas?
    Smykowski's Avatar
    Sep 2011
    3,065
    Yes, let the borax mix for 30 min, then you can test and adjust again.
    May 2013
    Pittsburgh, PA
    23
    Quote Originally Posted by Smykowski
    Nice. Going to test now!
  20. Back To Top    #20
    Richard320's Avatar
    Jan 2010
    18,967
    [center:2be9yb3l][attachment=0:2be9yb3l]chlorinator.jpg[/attachment:2be9yb3l][/center:2be9yb3l]
