Thread: Opening Numbers help please
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    Just opened our pool yesterday. The water temp upon opening was 54 degrees, and after running heater, temp is now 74 degrees.
    We have a vinyl lined 20k gallon inground pool and have a SWG. We have not turned on the SWG yet. We added 2 gallons of 10% liquid chlorine last night, which according to the pool cal, should have raised chlorine from 0 to 10.
    Just ran a test:
    FC 0.5
    CC 1.0
    TC 1.5
    pH 7.3
    TA 120
    I didn't do the CYA test yet (will be doing tomorrow) and then I just bought some powder CYA which I'll be adding, but if I remember correctly, it takes a week or so for the numbers to increase.
    The pool has had the solar cover on today, plus it was raining all day.
    Is it normal for my FC to be so low after adding 2 gallons of chlorine? Husband says the chlorine must be defective
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    38,290
    Re: Opening Numbers help please
    Well, clearly there must be something in the water consuming the FC. You need to test the CYA, dose for around 30ppm as required, follow the shock process (assuming the CYA is active even though it may take a week to show up on the test). Once the shock process is complete, then bump the CYA up for SWG levels and fire up the SWG.
    Apr 2009
    S.E. MI
    570
    Thanks, Jason, I appreciate it. Yeah, never had this problem with an opening before so it kind of surprised me. Water is crystal clear, but yeah, there has to be something consuming the FC. Will shock and hope for the best
    38,290
    There is no "hoping" required. It WILL work
    Apr 2009
    S.E. MI
    570
    UPDATE: Sorry I haven't posted back in a few days, my computer was down. Anyway, after 4 days of the shock process, I am happy to say that we passed the OCLT this morning. I still don't understand it. The whole time the pool was crystal clear, but CC was always 1 and chlorine would go from shock level down to zero overnight.
    Here's this mornings number: FC 23, CC 0, CYA 60
    Now I'm just wondering how long it will take for the FC to go down, then I will start the SWG. Thanks again!
    38,290
    Safe to swim up to shock level if that is a concern. You will likely lose at least 25% of the FC each day if you have a fair bit of sun.
