Results 1 to 13 of 13
Thread: Need pool pump advice
    Guessing this is still in the getting started forum.
    Have a single speed pump and want to go to a variable speed for noise and energy relief.
    What questions do we need to ask? Leslie is recommending Hayward over Pentair and one
    review of Pentair said there's an issue with electronic parts not being available and only
    option is full unit replacement. Little found about guarantees, or life span.
    36K pool
    300 GPM filter media
    6 panel solar heater
    CA valley location
    Thank you
    36K gal, gunite w/ plaster,[18W x 38L x 8 deep end] 300SF cartridge, 80-100 GPM filter, Sta-rite S7M120 and Polaris 9300 electric robot. Rooftop 6 panel Solar heater, Sacramento Valley, Climate Zone 8
    38,251
    Re: Need pool pump advice
    Leslie's is a Hayward dealer I think ... thus that recommendation.
    What is your electrical cost? If not too high, a 2-speed motor/pump might get you most of the electrical savings if you do not need a wide variety of flow rates.
    See Jason's post here:
    energy-efficient-pump-recommendation-t59139.html
    I thought variable speed was 30% more efficient than dual speed.
    http://www.mikethepoolman.com/variable_speed_pump.php
    Variable speed pool pumps are the first to use exclusive permanent magnet motor technology. This provides typical “base savings” of 30% over pumps with traditional induction motors.
    All electric is about 150/mo. Pump runs 7 hrs a day at probably 2000 watts
    38,251
    Did you read the link I provided? Specifically starting with this post:
    energy-efficient-pump-recommendation-t59139.html#p486563
    Yes the VS is slightly more efficient, but it really depends on your kW-hr cost and the relative costs of the pumps to determine if you will ever save enough in electricity to warrant the more expensive VS.
    Ok, read the article. Variable speed would be best for us as Nov-Apr the pool is not used, so could drop the speed of the motor and run longer. Need the higher speed in the warmer months to match the warm air and to move more warm water from the roof to the pool. Noise is a significant factor as well, almost as much as the electric costs.
    38,251
    There are also smaller VS pumps out now from both Hayward and Pentair if you do not need the high flow possible with the larger ones.
    Electricity is expensive where I am (NorCal - Sacramento area), especially during summer.
    I went with the VF and have absolutely no regrets.
    Low speed pump, with a big cartridge filter, it runs on avg at 300w, granted I kick it up to 90gpm for a couple hours morning and night to do some skimming and just improve circulation (my pool has issues...).
    Something I figured out about the VF, it calculates the "optimal" run time, based on factors you input, like pool volume, number of cycles, number of turns per cycle, etc.
    So if electricity costs can vary throughout the day (it is like that here), you should set the start time and end time of the main program accordingly, because the VF goes into "power save" mode at the end of the runtime. I would like power save mode to be say 1:00pm to roughly 8pm.
    The hottest time of day here is mid-afternoon, like 3-5pm, so everyone runs their AC then, and rates are highest.
    I want the pump off then, but on during the night and morning. I set the start time to 9pm and end time at 8:59pm.
    The pump is off during the expensive hours.
    As long as I keep the chemical balance of the pool good, and clean off the cartridge filters periodically, the pump rewards me with sparklingly clean water, essentially silent operation, and low electricity bills.
    15,000 gallon in ground gunite plaster pool, Pentair Intelliflo VF, Pentair Quad DE 60, Dolphin Oasis Z5
    Northern California
    andyt, thanks. we need to run some between 3 and 6 to get the most out of the solar heater. Water is about 75 now and we like it about 82, but air temps are more important. Finally this whole weekend it should be right around 100, yeah
    how long have you had the pentair? any issues with it? How much did it lower PGE, about $40?
    we've had the polaris for about 7 months now and does pretty good, but I do wish it would scrub a little more, but all in all it does better than a water powered sweep
    Hard to say, but when I first moved in 2 years ago I had to run the pump continuously for about 4 days to clear the pool, and my electric bill was over 300$.
    We normally run around 150$ a month in electricity now (summer) if that gives you any indication.
    I replaced the pump promptly after that bill, so I've had it right around 2 years now, no issues whatsoever.
    We have the 9300 Polaris also, and while it is a fine machine, it has trouble with our steps, good with leaves, but lots of dirt/dust/pollen will choke up the filter pretty quick.
    I had to replace the Polaris filter already (1.5 years out of the first one, not sure what is normal).
    Our electric cord died, and was replaced under warranty.
    Northern California
    Ok, thanks. Ours does steps fine. I've always been careful to reverse flush the filter after each use and run it at least once a week.
    Since that is such a fine filter, I would be surprised if it lasted 2 years.
    Appreciate the feedback. It's just a matter of deciding on a pump model, ordering it and having someone else install it.
    I did it the hard way and figured out the savings was $400 a year. And then I found the easy way, an online-calculator
    http://www.pentairpool.com/pool-pro/dea ... /index.htm
    38,251
    Those online calculators are not very accurate and tend to not compare things appropriately ... skewing toward making the VS look like a miracle.
    Jason's post in the thread I linked to above is much more realistic.
    mas985's Avatar
    Pleasanton, CA
    11,737
    If you want a more "fair" comparison than what Pentair presents, there is a link in my sig which contains a spreadsheet to do your own comparison. Your case makes a little more sense with a differential cost of around $20/month. Here is an example of the output:
    Mark
